rover 4.6 to t5 gearbox
Posted: Thu Jul 08, 2010 8:32 pm
by v8 pete
what clutch plate do i need
mine is slipping need to order a new one
dont have the part number.
hope to order before stripping out engine
Posted: Tue Jul 13, 2010 1:13 pm
by SuperV8
What T5 do you have?
The TVR sourced Tremac T5 has different spline size to the Cosworth BW T5.
Posted: Tue Jul 13, 2010 5:52 pm
by richardpope50
I had the same problem when I swapped from a TVR V8 to an SD1 V8 (temporary reason). I had to use the TVR clutch which is an AP clutch. Therefore you'll need an AP clutch for your 4.6. I would guess you will also need the whole assembly too and may be a bit pricey from TVR sources and as I want to change my plates I was going to try a motor factors but have not done so yet.
There were several numbers on my AP clutch plate but nothing seemed obvious as a part number but it's in my car at the mo so I cannot really read them off at the moment, sorry.
Posted: Wed Jul 14, 2010 2:51 pm
by seight
For what it's worth I'm using a CP2394-14 with CP2346-4 from AP which is a 9.5" setup on SD1 (I think) flywheel. Probably overkill in a light car like my Westfield. I think I could probably get away with a 'brown spring' version, my is the 'green spring'. But those part numbers are for the Cosworth T5 box spline, you may need a different plate.
Posted: Fri Jul 16, 2010 6:58 pm
by richardpope50
TVRpower.co.uk have clutch options.
Re: rover 4.6 to t5 gearbox
Posted: Fri Jul 16, 2010 7:49 pm
by DEVONMAN
v8 pete wrote:what clutch plate do i need
You will need to establish which flywheel you are using.
Range Rover or SD1 or TVR etc etc etc
Regards Denis
Posted: Wed Jul 28, 2010 5:40 pm
by v8 pete
flywheel not sure rover i believe [been lightened]
clutch plate is bogr warner 25'4 hole 23 spline 240mm outer dia
must be able to take 270bhp and 260 torque
Posted: Thu Jul 29, 2010 1:04 pm
by davehoos
Posted: Sat Jul 31, 2010 3:11 pm
by v8 pete
ordered a ford transit one
and see how that goes
Posted: Tue Aug 03, 2010 8:19 pm
by v8 pete
fitted and seems to work ok
