cooling cover
stagman
cooling cover
Post by stagman »
hi guys, i have fitted a electric fan to the rad, and wondered if i should fit a shoud cover over the rad, as well. most modern cars have them. i believe to push the air thro, the fan. what do you thing , paul
stagman
Your fan or fans should cover as much of the radiator as possible
By doing this you should not need shrouds
Cooling efficiency is related more to volume of air that the fan puts through the radiator
stagman
cooling cover
Post by stagman »
hi ian, thanks for that, i do cover most of the rad so i will leave it alone. paul
stagman
Rule of thumb is that a radiator will need approx 1/3 of rad size opening in front and about 2/3 clear behind it
Return to “Cooling Area”
