wade supercharger startup
Posted: Sun Apr 04, 2010 6:06 pm
by crappycresta
hi i am just about finished building a supercharged rover 3.9 with ro34 supercharger,my question is what is the ignition timing,for a supercharged engine.thanks Al
Posted: Sun Apr 04, 2010 6:27 pm
by JP.
38 total @ 4000 rpm for an NA engine & 32 total @ 4000 for a blown engine.
You could use a BTM module like one from MSD ignitions which will retard the timing when there is boost, meaning you don't have to recurve your dizzy and the BTM does it when needed.
On normal driving conditions you won't see boost so a boost curve on a street car will make the car lazy. You only need a boost curve under wide open throttle conditions and this is when the BTM module gets handy.
http://www.msdignition.com/product.aspx ... ing+Master
Re: wade supercharger startup
Posted: Tue Dec 07, 2010 10:02 pm
by Toyv8a
crappycresta wrote:hi i am just about finished building a supercharged rover 3.9 with ro34 supercharger,my question is what is the ignition timing,for a supercharged engine.thanks Al
Ihave jus acquired an ro34 for my 3.9i which will be going in the hi lux. Needs snout, pulley manifolds.
Are there pictures that I could find to get me started on the build? Thanks, t
ro34
Posted: Fri Dec 10, 2010 7:55 pm
by crappycresta
if i could figure out how to up load photos of my car ,i would put them up,the inlet manifold on my car is a cast alloy item ,that i have never seen on any other supercharged rover,it sits low in the valley,others i have seen are mainly modified standard inlet manifold,but the final setup is to high,try www.megadyne.co.uk,for drive belts and drive pulleys
goold luck
crappycresta
Posted: Sat Dec 11, 2010 10:49 pm
by Toyv8a
thanks crappycresta for getting back to me. will carry on looking.
THanks
toyv8a
