RV8 & T5 clutch options?
Posted: Sat Feb 17, 2007 7:41 pm
I have an RV8 mated to a Borg Warner T5 via a Rover/LR auto bellhousing with adapter plate. This is going in a seven, and although I built the chassis around the V8, I left very little space at the front of the transmission tunnel for clutch gubbins, so ideally I want to avoid the need to squeeze in a slave cylinder.
What have others done for a clutch when mating an RV8 & T5?
My bellhousing (obtained from ebay) is apparently meant to take a cable operated clutch, but that would be rather stiff no?
Perhaps the best solution I've heard of is using a concentric slave cylinder a la Saab - but I've no idea if this has been done with an RV8/T5, or what parts I'd need. Anyone?
Thanks,
Adam
Thanks,
Adam
