gearboxes
lee
gearboxes
Post by lee »
hi im new to the v8 scene and im hoping you will be able to help me with my question
basically im building a fwd 1981 metro with a rover 3.5 v8 under the bonnet but having problems with finding a fwd gearbox that will fit a 3.5 v8 :(
i know the princess gearbox will fit under the block but trying to find one of those gearboxes is near on as rare as rocking horse sh*t, so are there any other gearboxes that can be used for fwd?
hope you can help
lee
There are no standard FWD gearboxes that fit the RV8.
I think that Ralph85 has fitted a Rover PG1 to an RV8 for fitment into a Metro though......
lee
Post by lee »
ChrisJC wrote:There are no standard FWD gearboxes that fit the RV8.
yea i was hoping that there are other gearboxes from other cars which are of the same shape and can be adapted to fit :?
ppyvabw
Post by ppyvabw »
Wouldn't it work having the engine pointing longitudinally in the normal v8 position (squeeze it in some how lol) and having an lt77 box, then a tranfer box to redirect the motion to a front axle? Maybe a shortened axle from a small four by four, adjust the gearing etc....
By which time you may as well have put an axle in the back and have the transmission from the proper end rather than the front.
Post by CastleMGBV8 »
Much easier to mid mount the engine in a subgrame and use a renault transaxle for which there are adaptors available.
Personally I wouldn't use a Metro shell unless you do some serious stengthening to the front end as they tend to fold up very dangerously in a frontender.
lee
Post by lee »
ppyvabw wrote:Wouldn't it work having the engine pointing longitudinally in the normal v8 position (squeeze it in some how lol) and having an lt77 box, then a tranfer box to redirect the motion to a front axle? Maybe a shortened axle from a small four by four, adjust the gearing etc....
i was thinking about just making it RWD but dont think that the engine will fit like a normal V8 plus i would need to find a rear axel and diff unit the same length as the metro
may be a silly question but is the PG1 gearbox the one that is found in the MG zr?
ppyvabw
Post by ppyvabw »
mid engined like Kevin says.
Surely there aren't many FWD gearboxes to chose from that will take that much torque. It'll be dead within a week. Maybe from 'hot hatches' but still....
Were Metro 6R4s based on the original metro shell or were they completely different? Could roughly follow that design.
lee
Post by lee »
there is the four cylinder leyland princess gearbox that would fit and work with the 3.5 V8 but trying to find one of those gearboxes is like looking for a needle in a hay stack
yea 6R4's were based on a metro and from what i have read used a jaguar xj220 lump in the rear of the car
Richard P6
Post by Richard P6 »
I used a Renault gearbox from a 3L 'something or other' back in the mid 80's to fit my 3.5L Rover V8 into the back of a Countach replica.
I was sold an adapter plate to mate them together, so that I could get the engine mid mounted.
Even with this arrangement (Contact a GT40 or Coutach replica company for details) the engine will be sticking out of the front rather a long way.
Edit - it was a Renault 30 :)
jefferybond
Post by jefferybond »
ppyvabw wrote:By which time you may as well have put an axle in the back and have the transmission from the proper end rather than the front.
By which time you no longer have a Metro!
It would probably be easier to do that, and it would probably drive better too, but I can see the attraction of doing it the hard way and keeping it FWD, and honestly saying you have a RV8 powered Metro (rather than a metro look-alike!)
As for alternative gearboxes to the Princess box, there can't be that many surely? How many manufacturers other than BL put the gears in the sump?
Jeff
minorv8
Post by minorv8 »
I am not 100% but Austin 1800 (landcrab) might have a suitable box as well. I believe it is more or less the same as Princess. Not sure though if you have any luck sourcing one. NONE will fit directly as already pointed out, see pic below:
http://www.geocities.com/jharkola/image ... rover5.jpg
But, with patience it can be done: http://www.geocities.com/jharkola/image ... over12.jpg
Of all the V8 engined minis this car is still the best engineered example.
PG1 is just a Rover FWD box. As Ralph is doing this...he would definately be worth speaking to
What about early Saab boxes...didnt they sit under the engine ? Although height could be an issue
Early Saabs had a transaxle in front of the engine which in effect is back to front.
Later Saabs used the now more conventional transverse layout, the gearbox/final drive unit from a 2.3 Turbo might be worth looking at as the power and torque would have been similar to a standard/ mildly modified rover V8.
Personally I would still favour the mid engine layout if there is enough room behind the front seats, easy enough to get the dimensions of the length of a Rover V8 and Renault transaxle, at least you would know it would work and the car would have great balance and handling potential.
The Metro 6R4 was a V6 with the 4WD trans under the engine if I remember correctly.
Surely any FWD box will have the limiting factor of tyre traction and on acceleration the front wheel will spin so easily that there will be a limied strain on the box (perhaps blow the diff if one spins more than the other)
Or
Knowing that Metros crumple so much in a front impact
Use someting like a Renault or VW box with the engine behind the box and move the seating, pedals, steering rearwards thus a( getting you benihd the crumple area and b) putting the weight more central in the chassis
With a LSD you may get better traction off the line but expect to see a lot of smoke coming off the front wheels and fit a rev limiter as you will overrev it when it lets go!
lee
Post by lee »
i have been thinking about doing mid engined and RWD it just the fact that im unsure as to which rear axel to use that would fit an austin metro :?
however by doing that i would have to rear subframe, strengthen the rear, fire wall and completely remove the floor :(
