Anti tramp / slapper bars
Posted: Fri Jun 05, 2009 9:01 pm
by mgbv8
I got a quote of £140 notes ish for a pair that should fit??
I got me £20 worth of cut metal from the metal supermarket and went home to break out the stick welder and the pillar drill.
2 hours later they were made and this was bolted on. I just need to fix the bump stop and I'll be good to go for North Weald testing next weekend.
Posted: Fri Jun 05, 2009 10:46 pm
by JSF55
Just an observation on some i've seen, chamfer the front of the box section, it's easier to tighten the nut and also gives more "skid" if it should dig in to a kerb or similar, other than that well done
Posted: Sat Jun 06, 2009 7:30 am
by Darkspeed
Adding weight
- get the hole saw out.
And cut all the unnecessary thread off of those U bolts
Andrew
Posted: Sat Jun 06, 2009 8:45 am
by Ian Anderson
And I hought when I saw this thread that you had been out cleaning up the down market alcohol establishments in your area!
Posted: Fri Jun 12, 2009 5:57 pm
by mgbv8
Finished items.
I still need to trim the fronts and do some other tweaks. But they are ready for some test runs this Sunday. Hopefully I'll get enough time to trim the fronts before hand.
Posted: Mon Jun 15, 2009 12:42 pm
by mgbv8
WOW!!
They work ok
Hardly any roll and lots of G's off the line. I broke the drivers seat out of its mounts again as well
Posted: Mon Jun 15, 2009 12:43 pm
by Coops
ooooer
hope to have the rear end of mine setup this time at caprisport ready for the pod next year mate,
have ordered the axle brackets etc to make a set up like the escort 4 link
Posted: Mon Jun 15, 2009 1:11 pm
by ian.stewart
mgbv8 wrote:WOW!!
They work ok
Mmmmm the seat mount is trying to tell you something Perry,
Posted: Mon Jun 15, 2009 2:32 pm
by mgbv8
Yeah!!
Either get bigger bolts or lay off the Kebabs
Posted: Mon Jun 15, 2009 5:33 pm
by CastleMGBV8
Perry,
Do keep an eye on the front mount for the rear spring they are prone top pull ot with the amount of torque your putting through them.
Most of the US converters who use 302 ford lumps or similar, weld on some bracing which doubles the thickness at the bolt position and extends forwards along the box section for approx 12".
Good to see you sunday and meet up with Rich, I wasn't feeling that good as the bloody infection was comiong back yet again, so left shortly after 3PM.
The good news is I am going Bionic! I'm going into hospital next Sunday to have the plastic tube (Stent) removed from my right uretha, and replaced with some memory metal expanding stents, which hopefully will get me infection clear, and back on form again.
Then I've got to fix the MG, as you know I had an odd brake problem after setting out, and had to turn back and then drive up in the sludgemobile (Rover Sterling Coupe) anyway I've got a couple of Sundays after next when I'm in hospital to sort the brakes out before the Pod meeting and hope to see you all there and in much better form.
PS. Perry glad the slappers worked out for you! and Rich thanks for the burger.
