Range Rover clutch in to SD1 g/box?
Posted: Fri Mar 13, 2009 11:26 am
by nickm
Can anyone tell me if you can fit the RR clutch on to the 2wd LT77 gearbox?Thanks,Nick
Posted: Fri Mar 13, 2009 12:13 pm
by topcatcustom
I dont think so, the 2wd bell housing is a lot smaller than the 4wd version.
TC
Posted: Fri Mar 13, 2009 12:44 pm
by harvey
The 2WD LT77 will mate up to the back of the engine without any problem, its bellhousing is smaller than the 4WD one, but it obviously has a shorter imput shaft to suit. The problem is (IIRC) that the 4WD imput shaft, as well as being longer, is also of a larger diameter, so the 2WD imput shaft will be far too small for the splines on the RR centre plate.
If that is the case you would need a custom centre plate made having the o.d. of the RR plate, with the 2WD spline in the hub. (Assuming that the larger RR pressure plate doesn't foul itself on the inside of the smaller bellhousing.)
Re: Range Rover clutch in to SD1 g/box?
Posted: Fri Mar 13, 2009 1:13 pm
by bodger
nickm wrote:Can anyone tell me if you can fit the RR clutch on to the 2wd LT77 gearbox?Thanks,Nick
the RR clutch is a bigger diameter and won't fit inside the 2wd bell housing ..
this is a useful site for finding clutches
http://www2.qha.com/q-pid/QPID.aspx?user_id=&session=
slect clutches from the drop down box , you can compare sizes and cross reference too
Posted: Fri Mar 13, 2009 3:07 pm
by nickm
Thanks for the replies.Will swap clutches over.Shame as RR clutch that came on new engine looks brand new.
