Rossco wrote:Ok
Yes in theory it's big enough.
The thing that would worry me is the 2.4:2 overdrive. That's a very high overdrive and means that you'd have to set a 5200rpm engine limit.
As to why you're not showing any boost is a mystery.
Unlike turbo's superchargers do not need engine load to produce boost. They produce boost right from the word go. The reason is that a supercharger produces a fixed output of air per rpm, in this case around 2.2 litres per rpm. That figure is as I've said fixed from idle all the way to red line, OK it's not a perfectly linear graph but it's close. So you should see boost on the gauge even at low rpm.
I disagree.
If measuring boost in the intake manifold ( ie, between TB and engine ) then at low loads you will always see vacuum.
The only way I could see that you could get boost in there with no load, is to go WOT, but that would carry its own dangers/risks.
if you maintain part throttle, to hold a fixed rpm...the engine will still be in vacuum, just as it would when crusing at a fixed rpm.
