release bearing
Posted: Sun Oct 26, 2008 10:31 am
by Seight-V8
hiya all,
So with my new clutch came a new release bearing....hmmm metal flat type bearing clipped on to a composite plastic type carrier.
My orginial one, a metal round faced bearing on a metal carrier, standard SD1 type.
Question is...which one is gonna be best....Do i use the new plastic type or leave my old one in.
Anyone else used the plastic type in their engines and got any feedback.
Gonna be putting this thing in my 4.6 engine, so just need to be sure it will last or not melt.
My mind says stick with the old one...as its metal...
cheers
scott
Posted: Sun Oct 26, 2008 1:25 pm
by ian.stewart
Metal one, I managed to melt the surface of my flywheel and set alight to the cultch lining, still usind the same carrier.
Posted: Mon Oct 27, 2008 4:40 pm
by Seight-V8
hello all,
Anyone know if fitting a round nose bearing with a radius edge clutch cover will do any damage.
As you are supposed to fit a flat nose bearing with these clutch covers.
But i need to make the bearing shorter to increase clearance.
So will need to fit the metal carrier, but the flat bearings dont fit one these carriers.
cheers
scott
