Long nose crank spacer
Antonyj
Post by Antonyj »
Does anyone know the dimensions of the spacer that is required on a long nose crank to fit an earlier crank pulley?
Having some other bits made and want to get one of these made at the same time....
Post by CastleMGBV8 »
Antony,
The spacer is required if using an earlier style front cover on a long crank engine.
They are available from RPI
Mine measures:
ID = 35mm
OD = 45mm
Depth = 18mm
Antonyj
Post by Antonyj »
Cheers Chris , can get one made now!
