what socket do i need for rocker cover bolts
Posted: Mon Sep 01, 2008 7:48 pm
by blknight05
2
Posted: Mon Sep 01, 2008 9:41 pm
by RoverP6B
Rocker covers are attached, certainly in the case of my engine, with 4 screws, 1/4 UNC.
Ron.
Posted: Mon Sep 01, 2008 9:51 pm
by katanaman
I cant remember as I always change them for allen cap screws but it definitely wont be metric. If 8mm is loose then it will be 1/4.
Posted: Tue Sep 02, 2008 1:30 pm
by jrv8
They're 5/16" AF bihex
Jim
Posted: Tue Sep 02, 2008 5:42 pm
by TVRleigh
katanaman wrote:I cant remember as I always change them for allen cap screws but it definitely wont be metric. If 8mm is loose then it will be 1/4.
I think that's the thread 1/4 UNC not the spanner size your need.
5/16 would be right as that the closest to 8mm.
as other have said I always fit stainless cap heads.
Posted: Tue Sep 02, 2008 6:10 pm
by blknight05
22
Posted: Tue Sep 02, 2008 6:37 pm
by jrv8
blknight05 wrote:isnt 5/16 exactly the same size as 8mm ?
No, it's exactly the same size as 7.93mm
The socket size that you need is 5/16" AF bihex. You'll find it's a tighter fit than an 8mm one.
Jim
Posted: Tue Sep 02, 2008 8:35 pm
by blknight05
ok many thanks for your help
Posted: Tue Sep 02, 2008 9:15 pm
by bodger
on the rover V8 i have found if in dought try AF , as it was a yanky engine to start with and they are still quite few on it
