Hi Rev Misfire as in past 6k
Bit of a confusing problem,
on the rollers saturday the car was hitting well over 6-6.5k no probs at all.
didnt abuse car on way hoem and parked it up.
got car out yesterday, took for run, and now when it gets to just over 6k it holds back as if its on a rev limiter,
the limiter was set on 7.5k now set at 9 still does it,
have a new set of plugs and cap, no rotor arm as that was new a while back but may change it,
any ideas what it could be???
up to this missfire the car revs and pulls like a train every time. then plays up when it gets to just over 6k.
Unilite playing? cdi unit? leads? coil?
all advice welcome.
all advice welcome.
Different plug gaps?
Where did I read somewhere recently about RV8 high rev misfires & plug gaps ??
Found it: http://www.v8forum.co.uk/forum/viewtopi ... +plug+gaps
IanT + '54 RV8 Pop (° || °)
Marki,
a log of it is here, you can see the missfire as i held it foot to the floor to try and get a reading on the log while accelerating,
http://www.v8forum.co.uk/zip/newdatalog.zip
i started to fit a new set of plugs and cap before my holiday, so not had chance to test it yet.
Allan, did you get my email before i went on holiday friday regarding some mallory spares mate???
well the plenum is off at the mo as checking the pushrod locking bolts to make sure they are still tight,
will then reseal the plenum,
cheers mate,
that would be spot on
just hoping it's not the rotor arm,
as can't remember who i got my last one from,
may of been you on ebay thinking about it
right managed to get hold of another mallory cap today after work,
and a fitted the new plugs,
bolted all back together fired her up, sweet as all ways, took out on the road and ran as normal, until you let rip, as soon as you nail it to the floor and get near 6k the same miss fire is still there,
anything else?
coil?
leads??
dizzy?
starting to loose it with the car
anything else?
coil?
leads??
dizzy?
