NEW MORGAN V8
DR JONES
NEW MORGAN V8
Post by DR JONES »
Hello all,
Am new to te site and was wondering if anyone had any useful advice. I have a morgan +8 thinking of taking the Su's off and going with fuel injection.
regards aj
yup good idea,
easiest way is collect all the bits off a RR ordiscovery including the ECU and clean it up and fit it! I assume a you have a 3.5 in which case you will want the hotwire set up off a late 3.5 discovery. I would avoid a flapper type as it is crude, restrictive and old.
Your other choice is to get the manifold off either type, collect a hardware of sensors and throttle and buy an aftermarket ECU (megasquirt, vems MS extra etc) a better solution in the long run.
DR JONES
Post by DR JONES »
Hi, had the mog from new. looking for some kit that's first rate rather than ebay / scrapyards. Been out of the country for a few years -who's the best person or firm to approach for the good stuff -not too worried about funding. aj
you are not going to get new injection manifold for the rover V8 unless you go for exotic aftermarket kit. A discovery manifold and plenum can be bead blasted to get it to look like new, a throttle plate and position sensor can be got for new from various places, a VEMS, emerald or MS extra ECU are bought new the rover manifold is pretty good. If it were me I'd go this route, exotic inlet manifolds wouldn't be worth the cost unless you are tuning the engine
Post by CastleMGBV8 »
AJ,
If you want to do it yourself you could buy all the kit at reasonable cost from Alan Coote at Range Rover Heaven in Wiltshire. Tel. Mob. 07711 369785 you will also need a surge tank/filter and a return fuel line and you will need to match the ECU to the 3.5 engine.
Alternatively if money isn't an issue and you want some one else to do it ring Chris at RPI in Norfolk he runs a 5.5L +8 careful or he will sell you almost everything. Can't find their phone no but you'll find them on google.
Also plenty of information on EFI in the relative section.
The link to this site gives you all the information you need.
It's run by Eliot who frequents this BBS and could probably help with most of the parts.
http://www.mez.co.uk/TuningTheRoverV8-pt9.html
If your engine has done more than 60k miles it could probably do with a new cam and lifters which is an opportunity to upgrade to something a little better, also a pair of econotune/stage 1 heads from Peter Burgess would add significant power without affecting flexibility. Heads and cam with matched efi, expect 200-210BHP
DR JONES
Post by DR JONES »
Hi there,
Thanks for the comment -I agree there is a trade off but on balance I think Ill go the 450+8 hotwire route. So thanks for the RR heaven and MEZ prompt -I'll give them a bell.
As an aside are RPI the scrapyard gang in Norwich /agents for Real Steel/ rovatecs apprentice? Their Sadam style customer services to a couple of my colleagues was along the lines of go F**k yourselves rather than sorting out a pretty bad mistake on RPI's part. I think I'll give them a wide berth for now -they've got a pretty bad reputation in the mog fraternity and I'm frankly suprised they're still going.
Cheers for the advice aj
you missed the "give me your wallet" bit before the "F&^K yourself" :shock: 8)
Wotland
Post by Wotland »
If you listen to Chris he will be able to sell you the moon :lol: :lol: :lol:
450 racein
Post by 450 racein »
Hi Doc!,you are going to have to watch out for electrical snags on a open heart transplant sutch as it is on that one . kit aside std or moded hotwire you are going to want a good man on the electrical side , Paul Atkinson. Atkinson land rover diagnostics is top top uba good tel on 01215595255 in brum. can you will forgive the dr sarcasam .
Roger that on RIP/ oops rpi , robintec and thoes trained by the elisibub, hollo its john eals, leave me alone I want to die! .DB
r2d2hp
Post by r2d2hp »
Hi Doc,
If you want a 14CUX ecu fitted with Mark Adams Tornado chip together with 20AM airmeter and diag display unit let me know.
Return to “General Chat Area”
