Bottom pulley crank bolt.
Posted: Tue Dec 26, 2006 5:42 pm
How do you guys get yer bottom puley bolt done up so tight?
I had to get a big breaker bar, stick the car in 5th, handbrake on full, brakes on full, chock the wheels up and then go for it! I haven't found a torque wrench that goes up that high so i just go for it until i can't do it up any more. Even then i'm not sure its enough.
I want to get it right as my woodruff key (i've had to modify the later 60mm one to fit my early crank) isn't something i'd trust to take alot of load ref driving the pulley and associated components, oil pump and cam/valve gear. I'm gussing this is why its done up so tight to take the load of the key via the high clamping force?
