v8 Radiator Suggestions
Posted: Tue Jul 01, 2008 9:47 pm
by bigdawgv8
Hi all,
Need your help and ideas again.
Just got my V8 up and running but the rad just isn't up to the job (a left-over from the cars 2 litre days!)
Sierra Cosworth seems popular but they're getting scarce and pricey.
Need something similar size to Cosworth - W 735mm, H 310mm, D 50mm
Can anyone suggest a suitable rad and fans for a V8 in Morris Minor..................???
Martin
Posted: Wed Jul 02, 2008 12:15 am
by ian.stewart
Plenty of people use Audi 100 rads, you can get them German French and Swedish
Posted: Wed Jul 02, 2008 7:42 pm
by JP.
I am running a Sierra OHC rad for years now on our supercharged 3.5 without problems or what soever. Running the twin Sierra fans on seperate themp senders ( one left and one right ) and on seperate relays.
Have to mension that since we have an 16 row oil cooler with stat fitted the water temp is more stabil with outside 25+ degree Celsius temeratures.
Posted: Wed Jul 02, 2008 9:21 pm
by bigdawgv8
Thanks for the replies
ian.stewart wrote:Plenty of people use Audi 100 rads, you can get them German French and Swedish
What rad are you using Ian?
Martin
Posted: Thu Jul 03, 2008 7:47 pm
by plastic orange
I use an SD1 rad in mine with twin kenlowes - cools just fine.
Pete
Posted: Sat Jul 12, 2008 3:15 pm
by DrDeAtH
you could measure up a transit diesel rad. that should be big enough
Posted: Sat Jul 12, 2008 3:28 pm
by sidecar
Pilgrim Sumos (Cob replicas) use sierra 2.3 diesel rad turned up side down!
I've a fairly hot 4.6 lump that runs at 77-80 degrees with the above rad.
Pete
Posted: Sun Jul 20, 2008 7:04 am
by dave350v8
I fitted a transit diesel radiator to my chevy powered capri,works fine with two fans!
Posted: Mon Jul 28, 2008 5:54 pm
by motherofgod
I also have sd1 rad with a single fan, no problems
James
Posted: Sun Oct 26, 2008 5:32 pm
by Garth84x
will a radiator with a oil cooler at the bottom be happy to be upside down also?
garry
Posted: Sun Oct 26, 2008 7:20 pm
by Coops
Audi rad in my baby,
