Fitting SD1 Flywheel
Posted: Wed Jun 04, 2008 3:27 pm
by CastleMGBV8
I have a SD1 flywheel that I want to fit to a 4.2 R/Rover crank, the SD1 flywheel appears to be thinner than the Range Rover one because when we fitted the flywheel the boss of the crank protrudes through the bolting face and prevents the fitting of the ARP bolts ie there is not enough room for the socket between the bolt head and the boss of the crank.
Should the flywheel have a spacer at the rear to bring it flush with the boss for correct alignment with the LT77 g/box, if not, is there another solution to fitting the ARP bolts?
Posted: Wed Jun 04, 2008 3:39 pm
by chodjinn
Different situation but similar problem with regard to the bolts; my aluminium flywheel has counter-sunk holes for the bolts, and even then the ARP bolts wouldn't go right in. I asked about a spacer but V8D said no, use custom bolts. I ordered some hardened allen bolts from Burton Power I think, got several different lengths just to be sure and they were cheaper than the ARPs!
Posted: Wed Jun 04, 2008 4:07 pm
by katanaman
I turned the end of a socket down so it fits.
Posted: Wed Jun 04, 2008 4:54 pm
by CastleMGBV8
Thanks Guys,
Real steel also said use a turned down socket which is OK.
My other concern is with clutch alignment, but presumably if the clutch driven plate is still on the gearbox input spline it should not cause any problems?
Another thought if the flywheel ring gear is closer to the rear of the engine is the starter motor going to engage properly? Don't want to fit the engine and find it's got to come out again!
Kevin
Posted: Wed Jun 04, 2008 6:08 pm
by chodjinn
it shouldn't affect the starter motor mate.
Posted: Wed Jun 04, 2008 6:16 pm
by katanaman
Nothing spacing wise is different so long as you aren't trying to use a 4x4 box. End of crank is the same whatever engine you have all that is different is the flywheel isn't as thick/heavy. You could have problems using a 4x4 box with a 2wd flywheel or an 2wd box with a 4x4 flywheel.
Posted: Wed Jun 04, 2008 6:55 pm
by CastleMGBV8
Thats Great,
Kevin
