Renault Transaxle to Rover V8
Posted: Thu May 29, 2008 10:40 pm
I'm trying to put my car together but I'm having problems. It is a Rover V8 attached to a Renault transaxle, with an adaptor plate. I don't know the history of the car or the adpator plate set up. My problem is this:
When I mate the gearbox to the engine/adaptor plate and I look down through hole for the the clutch arm at the top of the gearbox, the end of the primary shaft on my gearbox is not long enough to go into the spigot bearing on the flywheel???? The adaptor plate is 15.5mm thick and I have measured the distance from the front face of the bellhousing to the end of the shaft, then from the mating face of the adaptor plate to the front face of the spigot on the flywheel where the shaft locates and the shaft will be about 2mm short!
I bought the kit part built - so I know nothing of the history. Are you supposed to get longer shafts when you use and adaptor plate? Or should I make up a top-hat spigot bearing or something? The strange thing is the car ran and drove around my farm when I got it!!!!! Now when I put it back together the shaft doesn't make it to the engine. I'm stumped.....maybe it never did make it to the engine and the release bearing etc was holding it in place. The shaft does seem to have had some wear and the release bearing is wrecked (it's only run for about 30mins in its whole life so far.
Two other questions:
1) Where do I go to get Renault gearbox spares
2) How do I identify my gearbox, as there seems to be a few numbers in different places?
Thanks guys, hope you can help. I'm typing this in desperation, covered in gearbox oil........
