14CU or 14CUX ECU Circuit Diag
Posted: Sat May 17, 2008 7:26 pm
Does anybody have a link or a PDF for the Lucas/Rover V8 14CU or 14CUX ECU Circuit Diagrams please.
Welcome to the well-known V8 Owners Forum, no matter what you drive if its V8 Powered you'll be made very welcome.
https://v8forum.co.uk/forum/
No just the almighty Prince of Darknessramon alban wrote: Is it a conspiracy from the depths of the CIA to keep the ccts secret?
Well I admit to being staggered by that. I guess it's a reverse engineered circuit though rather than the genuine article from Lucas. But no matter, the important stuff is there!ramon alban wrote:Hello Chris,
I've got the "less intellectual"4CU Flapper schematics for U.S. TR8/SD1/RR on my website.
They give a great insight what is going on inside, particularly with the full load acceleration enrichment circuits and other sensor input circuits.
Ramon
ChrisJC wrote: Well I admit to being staggered by that. I guess it's a reverse engineered circuit though rather than the genuine article from Lucas. But no matter, the important stuff is there!
I dont think reverse engineering would have generated those PCB layout but its clearly not a Lucas source.
Probably a US based franchised repair outfit who had to have the circuits and they just got pirated out of the side door.
Slightly OT - the Pin1 input (Tach signal) input circuit shows that there's no need for that external resistor (at least, not from a functional point of view)
Functionally perhaps, but I think on balance the 6.8 k ohm resistor + the 10 k ohm resistor forming a total of say 17 k ohm in conjuction with the 560 pico farad capacitor would have an effect on cleaning up the signal.
Take away the 6.8 k and the result may be different.
Then there is the issue of an accidental short circuit on the pin 1 side of the resistor?
All speculation of course.
