Understanding WBo2 sensors and the figures generated by them
Posted: Sun May 04, 2008 6:47 am
I'm not sure if this is the right area for this post but here goes.
Ever since I had a 4.6 Efi engine built locally here in dubai I've been having some problems with it. Massive over fuelling was my primary concern and lack of performance was close behind.
It's been a two year learning curve but eventually we think that we may have found a major flaw with the build. One of the heads was over- skimmed to a point where the compression was rediculas.
I purchased a Tech Edge WBo2 sensor and LX2 display from Australia and this week we completed the instalation along with the latest TEWBLOG software to log some of the perameters.
My unit will give me;
1) The Fuel / Air ratio at the Y peice and also on the two down pipes.
2) The RPM taken from the coil.
3) The TPS voltage taken from the TPS sensor.
4) The AFM voltage taken from the AFM wires.
Driving home last night was surprised or pleased to see that my Fual / air ration has gone from a 12/13. figure to a 15+ figure. 14.7 being the honest medium I'm told. So now I have gone from running super rich to running a little lean. Hopefully I can adjust this.
My main question is this. After logging a 50km drive I now have a set of numbers on my laptop in the way of a Windows Notepad file. It shows all of the values logged during my drive home.
How can I get to interprete these numbers and understand what they mean?
I know what the correct voltages should be at my TPS & AFM etc....these show up quite nicely along with the RPM AFR ratios.
Something else that surprised me was when I was running both the TEWBLOG software and the ROVACOM at the same time....the TPS & AFM figures shown on the display were different. ??!! How could that be?
