Any tips on bleeding the clutch slave cylinder on my LT77 Gents?
I have reverse bled it using a pipe from the brake caliper, pumping the brakes until the clutch master is full, and it seemed to work OK, but I don't seem to be able to select gears easily.
I am in the middle of a rebuild and have not been able to properly test the clutch. I have no seats, gear knob etc, and the gear lever is a small stubby job.
Any clever procedures or checks would be appreciated.
I am using Silicon fluid, and Redline in the box.
Regards
LT77 Clutch bleeding
- davemgb
- Helpful or Confused
I assume you have the standard MGB clutch master cylinder.
Last time I bled my clutch I had to unbolt it from the bellhousing and let it hang to get a bubble out.
Have you got a new master cylinder pushrod and clevis pin? These wear out quicker on the clutch than the brakes and you don't need to loose much travel to have problems.
