starter?
Posted: Mon Mar 31, 2008 3:45 pm
by Garth84x
Hi all, not sure if this is the right section for this but....
need starter motor advice, the rv8 i have is from a mid 70's range rover judgeing by the engine number, so what starter do i need for a 2wd auto box?
or can the range rover transfer bo be removed making a 2wd box?
if not a sd1 or p6 box is the one then.
is there a four speed 2wd auto available?
sorry for all the questions as the rv8 and all the bits that go with it are all new to me....
Garry
Posted: Mon Mar 31, 2008 4:30 pm
All the starters are interchangeable as far as the block & engaging with the flywheel are concerned.
The 4x4 ones have the solenoid on the side (to clear the propshaft), and the 2WD ones have the solenoid on the bottom. I think! :lol:
Anyway, I have a 4x4 one on my 2WD auto (ZF) engine & box.
Posted: Sat Apr 05, 2008 4:13 pm
by DrDeAtH
you want the SD1 drop solenoid starter this will be the most compact solution for you.
