RV8 Angle
Posted: Thu Mar 06, 2008 9:23 pm
by Ralphh85
would a V8 mind being layed down a bit? current K series sits at 15 degree's or something, would a V8 be ok with this?
i may have to revise the oil level, but can anyone see any other problems?
Ralph
Posted: Thu Mar 06, 2008 9:38 pm
by sidecar
Angling the block back about 5 degrees so that the front is higher is supposed to help prevent oil being stored up in the heads.
15 degrees may cause issues with getting the carb to function correctly.
Pete
Posted: Thu Mar 06, 2008 10:20 pm
by Ralphh85
sidecar wrote:Angling the block back about 5 degrees so that the front is higher is supposed to help prevent oil being stored up in the heads.
Pete
ahh have wrong end of the stick, its transversely mounted in the rear of the car, so it would lean forward, so the front bank would be lower than the lower than the rear bank??
do you think this would be ok?
Ralph
edit, also i intend to use injection rather than carbs anyway.
Posted: Fri Mar 07, 2008 8:19 am
I think you'd get issues with oil pooling in the lower bank rocker area, and probably permanently leaking out of the gasket!
But I can't think if anything else that might be an issue.
Why do you need to do this?
Posted: Fri Mar 07, 2008 8:22 am
by sidecar
ChrisJC wrote:I think you'd get issues with oil pooling in the lower bank rocker area, and probably permanently leaking out of the gasket!
Yep, same as what Chris said!
Posted: Fri Mar 07, 2008 12:15 pm
by Ralphh85
it would have made weight distribution better, but i can probly make it mount pright anyway, look better upright to!
will know after this weekend, gonna go measure one up etc.
cheers
Ralph
Posted: Fri Mar 07, 2008 12:35 pm
by ian.stewart
The main problem may be with cooling, with one head higher than the other, and it being higer than the thermostat housing, bleeding air from that head would be a real PIA, this could possibly be overcome by drilling and tapping the head at the waters highest point into the jacket, then run a pipe to a expansion tank
If its a carbed engine, float levels would possible be another issue,
And minor oiling probs could include the dipstick tube need lengthening to stop oil being ejected out of the tube, The windage tray may need modifying or discarding to prevent the oil pooling in the wrong place as well, a Custom dry sump would be the Ideal way to go, not too expensive to get it cast either if you can make the patern
The oil retention in the head could be simply overcome by drilling the head in a couple of places at its lowest point, and fitting some drain tubes to the sump, the upper head possibly may not be a problem with drainage,
Posted: Fri Mar 07, 2008 6:12 pm
by ppyvabw
Might Oil starvation be a problem under hard breaking? Baffles in the appropriate places might be a good idea to stop the oil sloshing forward
Posted: Fri Mar 07, 2008 7:35 pm
by Ralphh85
think i will keep it upright!
Ralph
