LT77 and SD1 Flywheel
Posted: Mon Dec 10, 2007 5:20 pm
by TVRleigh
Hi can you lighten the SD1 flywheel.
Leigh
Posted: Mon Dec 10, 2007 5:31 pm
by katanaman
Yes would I recommend it no. If a flywheel shatters it will take you feet off.
Posted: Mon Dec 10, 2007 10:47 pm
by 5000SE
While Katanaman's comment is true about possible consequences, a flywheel that has been sensibly lightened will be no weaker than the original, because the material removed will mostly not contribute to its strength, and by reducing a lot of the outer weight you can actually reduce stresses.
If you’re building a real screamer of an engine, you have to be careful and not just let any grunt with a lathe cut metal from the wheel. If you’re running less than 7000rpm, it’s highly unlikely, even if you go to town on the flywheel, that anything will go wrong.
Posted: Tue Dec 11, 2007 1:53 pm
by Rick-Manta
I'd think it'll be a near pointless expense. The difference a lighter flywheel will make to most SD1 applications will be unnoticeable, IMO this sort of work is better suited to high revving screaming engines over engines generating low-mid range torque.
Yikes! Marki's made me feel better about splashing out on a new flywheel over my current one which is full of light cracks, I was going to skim it but the friction surface is already buried far below the outer wheel!!
Posted: Tue Dec 11, 2007 2:34 pm
by 5000SE
Rick-Manta wrote:I'd think it'll be a near pointless expense. The difference a lighter flywheel will make to most SD1 applications will be unnoticeable, IMO this sort of work is better suited to high revving screaming engines over engines generating low-mid range torque.
A lighter flywheel will still make a noticeable difference to the speed the engine revs up when downshifting - and for much crisper, more purposeful 'blipping' from idle!
Posted: Tue Dec 11, 2007 5:42 pm
by TVRleigh
Well its going to be semi high reving as will be used on a race car, but will be limited to max 4.0 and max 230 BHP. so will go up to 6-7k but not over.
Anyone know of any company's in the South East / Essex Area, that could do this work.
I have some other work that needs doing so hopfully somwhere that specialises on RV8's
Leigh
