Quaife LSD
Posted: Thu Nov 22, 2007 2:30 pm
by JC.
I've managed to aquire a brand new rear 3.07:1 rear axle for my MGB GT V8 conversion project.
How much power can I put through this thing before it breaks?
I'm hoping to use this hard on the strip you see.
Would it take say 350bhp on a hard launch?
Posted: Thu Nov 22, 2007 2:46 pm
by mgbv8
The axle will be good for 350hp JC. So dont worry.
Posted: Thu Nov 22, 2007 8:54 pm
by davemgb
I assume from the title of the thread that you have the Quaife diff in the axle. If not I suggest you fit something because the centre pin in the original open spool is prone to coming loose with disasterous results.
Posted: Fri Nov 23, 2007 1:47 am
by JC.
You've lost me, Dave.
Its a '68 MGC wire wheel 3.07:1 axle with the quaife difflocker fitted?
Posted: Fri Nov 23, 2007 9:49 pm
by davemgb
Sorry JC,
The original MGC diff has gears inside which are on a bearing pin, that pin is in turn held in the diff by a roll pin that has a reputation for failing and allowing everything to fall out.
Since you do have the quaife fitted you don't have that to worry about.
Posted: Sat Nov 24, 2007 3:57 pm
by mgbv8
Dave!!
Ask the jammy little sod how much he paid for the Quaiffe diff???
Posted: Sun Nov 25, 2007 5:56 am
by JC.
Perry, the axle cost me £500 but the Quaife diff was free. 8-)
Posted: Sun Nov 25, 2007 1:11 pm
What about the US GM 10 bolt....
Plentiful in the US. I know the modern Camaro guys get rid of them, and upgrade to stronger.
http://www.britishv8.org/Articles/2007-TechSession6.htm
Posted: Sun Nov 25, 2007 1:53 pm
by mgbv8
Stevie
D&D fabrications do the 10 bolt axle already modified to roll under an MGB and bolt up.
I'm still saving for mine. With the exchange rate at the mo this axle would cost about 700 quid + shipping + import duty. So a real good alternative to a UK sourced Ford 8" or 9" to fit an MGB. It comes with all the brakes as well for that money.
