3.9 compression upgrade
Posted: Thu Nov 08, 2007 1:27 am
ok my engine has the standard high comp 9.35 heads and at the moment im getting 10.5 bar from all of 8 cylenders.....
from what i already no from V8's the more compresion you have the more power you get (in lame terms that is) and usualy to increase the CR you have to buy different piston to increase it or buy some stupidly exspesive prices for some racing heads......
what i was thinking was, what about if i had the heads skimed so the combution chamber is smaller which would increase CR???????
i know ill have to be careful on how much to take off as the valves might foul, but do you think this is possible?????
now for a bit more complex thinking...... if this is acheived then what will happen about pinking!!!! will i have to retard the timing, or will i have to adjust the fueling to add more fuel to try and stop it from pinking......
how much would have to be skimmed off the heads to increase the CR, as the combutuion chamber isnt square its difficult to work out the volume of it before and after, it isnt realy ciurcular neither so its going to be very difficult to work out.... think this one is for the clever champies out there!!!!
