Rover Efi Throttle Pot Setting
Posted: Wed Oct 24, 2007 3:25 pm
by ramon alban
Most of us who have bog standard Rover Flapper Efi Systems know we must adjust our throttle pot to be 0.325 volts above zero at the idle position of the throttle?
It's not Zero nor 1.0 volts. It's 0.325 Volts. But WHY?
I cant recall ever seeing a written explanation (reason) in any "Rover" documentation and although I have heard a few different opinions none ring true.
UNTIL NOW!
In another forum I was explaining that the Rover ECU "FULL LOAD ENRICHMENT CIRCUITS" are triggered when the throttle pot reaches 4.3 volts at 90 degrees of rotation, or full throttle.
Feedback from some members indicated this was not common knowledge yet that fact is clearly described in the original Rover Technician Training Manual. See below, a scanned image from page 14 of that manual.
It then dawned on me that to guarantee the ECU would see a full 4.3 volts at 90 degrees of rotation, a small offset at idle position is needed.
So, if normal tolerances for analog circuit components (say 5%) apply, then, if for some circuit tolerance reason the full load enrichment circuits saw something lower than 4.3 volts, they may not be triggered.
Now, 0.325 volts is 7.5% of 4.3 volts so by specifying a 7.5% offset, this would ensure that the circuits were always triggered at full throttle providing there were no overt mechanical reasons preventing full 90 degree rotation.
For the first time in 14 years, and without the benefit of the designers' knowledge or reasons, this seems like a good explanation of why the setting is so specified.
Can anyone throw a different light on this subject?
Posted: Wed Oct 24, 2007 8:30 pm
I was under the impression that the only thing that the throttle pot did was trigger the 'sudden flooring of throttle' enrichment, i.e. the analogue of a carburettor throttle pump.
You can test this by rapidly opening the throttle (with the engine off but the igntion on), you can hear the injectors all pulse.
And so I couldn't ever see the point of setting it up accurately.
But if Ramon is right, and it does this extra function, then the setting up of it makes more sense.
Posted: Wed Oct 24, 2007 9:14 pm
by ramon alban
Chris. It's not if. I'm simply pointing out what Rover wrote in their training manual showing that there are at least two TP functions. Acceleration Enrichment and Full Load Enrichment.
So given that it is what it is, then my conjecture for a specific idle setting focusses the mind on Rover having to ensure that the latter is triggered and if it is set up right then it would also make a difference to full throttle acceleration and the 0-60 drag time.
Posted: Thu Oct 25, 2007 7:10 am
Semantics :wink:
