probabaly a boring cooling system question!!
Posted: Sat Aug 25, 2007 8:42 am
Have searched for this info but can not seem to get a definative answer on it as there seem to be many different options.....building a kit car at the moment RV8 3.5 no special mods apart for slightly hotter cam, am at the stage of plumbing in the cooling system and need advice on a header/expansion tank.
The radiator I have has the normal inlet/outlets plus it has a separateinlet about 1/3 the way down the radiator below the inlet. The inlet manifold has a small pipe slicking out to the front of the engine which I believe is a vent pipe but I stand to be correct if it is not!!
The set up I want to use is as follows,
Radiator inlet to thermostat housing,
Radiator outlet to the water pump,
Header tank outlet to the small inlet on the radiator below the main radiator inlet to allow the system to be filled through the expansion tank,
Small outlet on the inlet manifold to a small inlet on the header tank to allow the system to vent air.
Standard heater matrix set up from the rear of the inlet manifold.
Expansion tank with a pressure cap to vent if pressure builds up
Headrer tank needs to be the highest point in the system (what level above the vent pipe on the inlet manifold)....
Would this work, am I in danger or problems, or what am I doing wrong!!
cheers
Chris
cheers
Chris
