Well having pondered the thought of replacing my sd1 engine and 5 speed box in my minor for a 5 litre rover, but I'm thinking more of a LS block and tremec, I would like to know if the dimensions etc would be fine ( i think it's actually shorter than my current E/B) problems with engine injection/management system, I run a weber 500 at present so no wires! I have jaguar IFS and wonder on any manifold problems. Also what block LS1,LS2 etc, LS7 is to expensive at mo. Also what is the clutch mechanism on a tremec is it similar to LT77?
Any thoughts welcome
James
LS engine and tremec 6 speed Q's
Re: LS engine and tremec 6 speed Q's
What block do you want ? LS1, LS6, LS2, or some of the LQ iron or smaller cc 4.8 or 5.3 versions ?motherofgod wrote:Well having pondered the thought of replacing my sd1 engine and 5 speed box in my minor for a 5 litre rover, but I'm thinking more of a LS block and tremec, I would like to know if the dimensions etc would be fine ( i think it's actually shorter than my current E/B) problems with engine injection/management system, I run a weber 500 at present so no wires! I have jaguar IFS and wonder on any manifold problems. Also what block LS1,LS2 etc, LS7 is to expensive at mo. Also what is the clutch mechanism on a tremec is it similar to LT77?
James
So much choice, but for the first few, it makes little odds really. They are all excellent and have same tuning potential, and same bolt on parts.
An LS is slightly wider than a RV8, slightly shorter overall ( to a degree ). Height when fuel injected is lower than a RV8, but if you throw a carb onto an LSx, it will be a fair bit taller than equivalent rover engine.
When you mention clutch mechanism....well, its hydraulic. So its the same, but of course at the box its totally different. Makes little odds. If you want it to work you just make it work. Its not that difficult.
But as already mentioned, the T56 is pretty damn big. Bigger in every respect than a LT77, but infinitely better.
www.ls1tech.com
