Intermediate cover
Posted: Thu Sep 10, 2026 10:43 am
by Ray944
Hi everyone
Despite searching the planet for the correct serpentine harmonic balancer / crank pulley for my intermediate front cover Ive drawn a blank !
So can anyone tell me if I can use a V belt set up with my intermediate front cover instead please
Any advice is much appreciated !
Cheers !
Ray.
Re: Intermediate cover
Posted: Thu Sep 10, 2026 3:22 pm
by SuperV8
No, the intermediate front cover uses a coolant pump designed for the serpentine belt - which runs on the back of the belt so runs the opposite way to the V belt coolant pump.
To use a V belt crank pulley - you'd need to change the whole front cover to the older cover.
If you need a new crank pulley - you might be able to use the later GEMS crank pulley - with a spacer for the longer crank snout?
Posted: Fri Sep 11, 2026 8:57 am
by paul c
err3442. google shows several suppliers
Posted: Fri Sep 11, 2026 2:32 pm
by Ray944
Thanks for your replies. I might try the ERR3442 crank damper, but anyone have an Idea where to get the serpentine pulley for the damper from or even a part number please.
Ray.
Posted: Fri Sep 11, 2026 2:50 pm
by SuperV8
ERR2799 serp pully looks like it matches that damper.
Posted: Thu Sep 24, 2026 3:51 pm
by Ray944
Thanks for that - all ive got to do is find one !
Posted: Mon Oct 19, 2026 7:37 pm
by mgbloke
I have an intermediate crank pulley and water pump pulley that I would sell as a pair £100. Located in Westbury Wiltshire. You probably have it sorted by now though.
Mark
