Shaking down my rebuild - a few issues...
Posted: Wed Jul 08, 2026 4:18 pm
I’ve been shaking down my RV8 3.5 for a while now, with a lot of support from everyone here - very grateful.
My testing trips get longer as I bed down the engine (about 100 miles on it so far), but I’m still plagued by problems as soon as I clock up a few miles on faster roads. Broke down today, so determined to get it running more reliably. As ever looking for some advice...
Main problem is the amount of smoke it’s now putting out. I had this problem previously and needed to have a new valve seat pressed in. Something had slipped down the spark plug hole and caused some damage to the piston and seat. Problem solved.
This seems to be a new problem (I think) which might be caused by a leaking heater valve, dripping coolant onto the v gasket and mixing with oil. I found a lot of coolant sitting on the gasket and could see it dripping from the heater valve. Although I’m not sure liquid can get past the gasket & rubber seals but I guess it wouldn't take much. I’m going to block off the heater valve, change the oil and see if that solves it. What do you think, is this plausible, or should I be looking elsewhere?
The second issue that worries me, but I don’t think is currently causing it to run badly, is the harmonic balancer. It wobbles a lot. The main shaft it's attached to seems ok, runs straight. Could this become a bigger issue and be putting strain on the crank, bearings or seals?
I've attached a few videos so you can see what’s happening.
Wobble on the harmonic balancer
https://1drv.ms/v/c/f2cf483bba82bf78/IQ ... w?e=JhE2WO
Smoking and balancer - engine running
https://1drv.ms/v/c/f2cf483bba82bf78/IQ ... 4?e=JoIUNg
Any help and advice, much appreciated.
