New engine no oil pressure.
Posted: Mon Jun 29, 2026 8:12 pm
Hello looking for some advice I have rebuilt a 4.6 serpentine motor tand dropped it in my tvr wedge I filled the oil up today and cranked it over without the plugs in but no oil pressure registered at all.
I didn't realise I had to pack it out with vaseline when I built it.
I have taken the remote oil filter off and tried priming it that way with no success I also poured some in through the pressure switch opening.
The oil pump was stripped and cleaned thoroughly relief valve cleaned and replaced now one thing I did do was use the remote filter system that was on the original 3.5 motor not sure if it could be the issue or are they all the same?
Ps new oil pump internals were used.
