Rover V8 serp oil pump relief valve
Posted: Tue Apr 29, 2025 8:22 pm
Hi all,
I want to replace the oil pressure relief valve for my 5L build. I have the interim Serp cover with Dizzy.
The plunger/piston and spring don't look like they are available anywhere. I have read that they never were. All you could get was an entire new front cover, apparently?
I reckon I can pick up a suitable spring of a similar rate, but not sure about the plunger.
It looks very similar to the plunger for 300TDI, which Rimmers do have.
https://rimmerbros.com/Item--i-ERR1085P
Does anyone know for certain whether it is infact the same part, or could be used interchangeably?
My plunger doesn't look too bad, just some slight wear marks on it that I cannot feel with my finger Not scored, so may end up reusing it if I can't get one.
Any help greatly appreciated
