Have I dislodged my clutch release arm?
Posted: Sun Sep 01, 2024 10:47 pm
I'm desperate.
I have a Replica Cobra with a Rover V8 engine and LT77 gearbox. The pair came out of an SD1 . I built the car around 30 years ago and all has been fine until I recently had to change the engine ( That's another story !). It seemed a sensible time to renew the clutch slave cylinder so I fitted a replacement. Clutch would not disengage and there seemed to be too much free movement on the pedal . The new slave cylinder had come with its own pushrod which I had not fitted because I couldn't see how so I refitted the original slave. This worked and I had a clutch - this made me assume that there was some difference in the new slave that meant I had to use the new pushrod and I hadn't done that, hence the lack of success.
About a week later - no clutch ! On investigation I found the fluid had disappeared . The reinstalled old slave had obviously not liked the cleaning I had given and it was leaking fluid badly . I checked the new slave against the old one and they looked virtually identical so I reasoned it should be fine with the original pushrod. The new slave was re-installed and the system bled. The pedal still had a bit more free travel than i liked but it felt as though the clutch should be disengaging - but it wasn't
My manual warns that when changing the slave cylinder the clutch release arm is easily dislodged - I have been careful during all these changes but I just can't see why my clutch is not working now. Have I dislodged the release arm? And , how can I tell? The pushrod is poking out of the gearbox just as it was before the cylinder change .
I'd really appreciate any hints or guidance - Many thanks
Baggy
I'm desperate.
Baggy
