Holley Sniper efi
Posted: Tue Jul 16, 2024 3:21 pm
My current setup is twin SU's, distributor, timing cover, oil pump etc from a 3.5 RV8 on a 4.6 block and heads. I had the carb needles profiled on a rolling road and although I thought the 'profiling' was crude, just a long flat and a couple of notches filed down them, it did run well.
However, a few years later and it's slowly running worse and on stripping the carbs I saw the needles are worn and scratched as if someone's run a wire brush in an angle grinder up and down them! (presumably the needle jets will also be chewed up)
I couldn't find the answer before and still can't about which needles work and I don't want a full efi system so was looking to change to a Holley/Edelbrock/Weber carb when I came across the Holley Sniper efi system.
It appears a good choice, I can keep my distributor, it's got a built-in ecu and even looks like someone as hopeless as me with computers can get it set up and working properly.
Any thoughts on any of this?
