SOLVED 3.9 (carb) Cam Selection Help Please
Posted: Sun Oct 02, 2022 12:05 pm
Hi all,
Newbie here asking for some advice please. I have searched extensively on this and other forums but can't find an answer which suits this particular situation.
I have a 1975 factory MGB GT V8. All standard spec., i.e. manual, twin SU carbs, standard inlet & exhaust system etc.
I just want 'standard' performance commensurate with a good 3.9 (not fast road, racing etc.). Smooth idle & broad spread of torque.
As part of my engine rebuild I have had 3.9 liners fitted by Turner Engineering. I bought standard 9.35:1 compression pistons.
My question is which camshaft should I choose. None of the camshafts listed by the usual suppliers seem to match my engine set up (no camshafts are listed as suitable for a 3.9 with carbs). Turner's didn't have a definitive answer.
The available options seem to be:
1) ERC2003A. This is the standard 3.5 camshaft, listed as suitable for carb & EFI, all CRs. This is what my car has at the moment. How would this perform on a 3.9? It's not listed as suitable for 3.9 engines.
2) ETC6849 Listed for 3.5 Defenders / RR Classic / Discovery 1. How does this differ from the 'standard' camshaft above? Meant for automatics maybe?
3) ERR5924 Listed for 3.9 EFI. As all factory 3.9 engines had EFI how would this perform on my 3.9 carb set-up? Any downside?
4) 'Performance' cams. The most likely option seems to be the Kent H180. But Rimmers say this also requires uprated cam followers and valve springs. I already have new standard followers I bought from Turner's so don't really want to buy uprated followers. Also I don't want to mess about with buying & setting up a vernier cam sprocket & timing gauges etc. I just want a straight swap. So are the uprated followers & springs & vernier cam timing actually necessary?
What would the learned members here suggest for me in these circumstances? Any advice would be much appreciated.
Thank you
Chris
Thank you
Chris
