Edis ignition and aftermarket ECU's
Posted: Sun Nov 26, 2006 2:37 pm
by ozrover
Does anyone have any experience using an aftermarket ecu in conjunction with a Ford edis module? I need to run my Lumenition C460 distributorless on an RV8 and unfortunately the ecu only has 3 ignition drivers so can only do direct fire on up to 6cyl. Any help/advice appreciated.
Doug
Posted: Sun Nov 26, 2006 3:07 pm
by kev_the_mole
Doug,
try sending a PM to Bill Shurvinton on this forum.
Posted: Sun Nov 26, 2006 11:19 pm
by Richard
2nded. Talk to Bill - he knows MS'nS and MS'n'EDIS (or Google for MegaSquirt EDIS).
Posted: Mon Nov 27, 2006 11:51 pm
by bill shurvinton
You can't drive the EDIS with the lumentition, but the megajolt will do the job nicely probably for a lot less than you can sell the lumenition for. If you look on the LR4x4 forum there is a lot of good info there on installs for V8s.
I don't have any connection with megajolt anymore. Not because it isn't a great way to DIY yourself to better ignition, but someone else came along who (as well as being my boss at the day job) could give more time to help and support that I can manage.
I would still dearly love to come up with something between megajolt and the fuller featured DIY ECUs. one day maybe.
re
Posted: Tue Nov 28, 2006 3:23 am
by ozrover
Thanks for he replies.The Lumenition ecu runs the fuel injection and had the 3D ignition capability as well which I had hoped to use.Looks like I may need to source an intermediate timing cover and us the low data mode of the ecu and a dizzy rather than direct fire.
Doug
