Sd1 timing cover on late 3.9 serpintine engine
Posted: Sat Aug 04, 2018 4:37 pm
by Lmy78k
Can I fit a sd1 timing cover onto a late serpentine 3.9 intermidiate discovery engine
Thx
Re: Sd1 timing cover on late 3.9 serpintine engine
Posted: Sun Aug 05, 2018 8:07 am
by Blown v8
I fitted one onto a 4.6 lump,
So I can't see any reason why not !
Posted: Sun Aug 05, 2018 9:46 am
by DEVONMAN
Yes, provided you use a sump and oil pickup from a 3.9 or sd1 engine then it will work. The sump on later 4.6/4.0 crossbolted engines are different at the front end (an extra bolt) and have a different oil pick up arrangement.
Posted: Tue Aug 07, 2018 4:08 pm
You might need a spacer as the crank may be longer.
