So,I had a look on-line. Sounds simple....remove drain plug, then refill to the top of the other plug half way up the gear box.......Only, my gear box does not have a filler plug!....Im sure it's an easy one, but do I just pour approx. 2.8 ltrs into the breather hole at the top of the box?.
With regards to the transfer box at the rear of the gear box.....this also has a drain plug...does this need to be refilled separately? ...How much and where from.
Im not going mad either...here are the pics to show there is no fill plug:
