LT77 rubber mounts
ratwing
LT77 rubber mounts
Post by ratwing »
Between the two bobbins is a vertical bolt with a bush - I'm guessing it's to put some compression on the bobbins so the rubber isn't pulled off the metal ends but how much does the bolt need to be done up?
Seight-V8
Post by Seight-V8 »
I've removed mine, so its not used.
The rover SD1 manual calls it a "snubber", and it has a 3mm gap between the underside and the gearbox mounting cross member, so its not actual touching anything.
I would love to know what it actually does....hopefully some one has the answer.
regards
scott
ratwing
Post by ratwing »
Interesting - I just assumed it was to stop any twisting motion from putting the bobbins under tension but maybe not...
I think its there to assist the other rubbers in the event of shock which may cause the box to dip hard down onto the other rubbers.
petervdv
Post by petervdv »
There is s bolt with a circular rubber fitted into this hole. The rubber is on the outside into a concentric hole in the chassis transmission mounting bracket. Its there to limit turning of the engine due to torque
Peter[/url]
