Recommended Fuel Pump
Posted: Mon Jan 04, 2016 12:53 pm
Hello & good afternoon
As the title suggests, can anyone recommend a suitable fuel pump (external) to run my 4.6 Efi which I have fitted into my Land Rover 90?
The engine/gear/transfer box setup came out of a Range Rover Classic LSE, which was originally a 4.2 when it was new in 1993 (K reg). It was recalled by Land Rover when it was 5 years old for engine related issues & was fitted with the 4.6 & uses the 4.2 injection/ignition system. When I removed it from the Range Rover, I also removed the engine wiring harness along with ECU (14CUX), so I am in the process of connecting everything up, but need a fuel pump.
Thanks in advance,
Simon
Thanks in advance,
Simon
