Trigger / Ballast Resistor for EFI
Posted: Tue Jul 14, 2015 7:21 am
by paulsv8manta
Hi guys,
I've been trying to source a replacement resistor (Lucas p/n RD953066)
but have had no luck.
Have been looking on ebay and there are a number of 6.8K ohm available but are all with various watts from 10W up to 100W!
Anybody know what wattage I should be looking at?
Paul
Posted: Tue Jul 14, 2015 9:23 am
IIRC by that part number it's the resistor which goes between the coil 12v negative and injection to provide the engine speed signal (tach) to the injection.
So it's not a power resistor of the type you'd use as a ballast resistor for a coil.
I'd use a 0.5 or 0.6 watt type which cost pennies. But that is the bare wire ended resistor - the Lucas one is fitted to a case and has terminals at either end.
I may have the correct Lucas part lying around - I'll look later.
Posted: Tue Jul 14, 2015 10:42 am
Found one. PM me with your address and I'll pop it in the post.
Posted: Tue Jul 14, 2015 5:46 pm
You don't need it for the engine to run. It is irrelevant as far as I can tell, my only explanation is that it is needed for interference on the radio supression or something like that.
