What's the difference between these sump gasket kits?
Posted: Wed Jun 10, 2015 10:35 pm
by Magicdrshoon
I'm looking for a gasket kit for the water pump and sump (and probably a few others by the time I'm finished!).
Looking at the Rimmer Bros site ( http://www.rimmerbros.co.uk/Item--i-GRID008874 ) there seems to be 5 items which have the same components included, but ranging in price from £12.50 to £70 for the genuine Land Rover kit.
http://www.rimmerbros.co.uk/Item--i-STC1639P
http://www.rimmerbros.co.uk/Item--i-GUG1538CSP
http://www.rimmerbros.co.uk/Item--i-STC1639P1
I notice that some of them stipulate that they are for post 1991 engines, but not sure why.
There's still two to choose from which are for the SD1 engine.
Does anyone know if there is much difference between them?
Cheers.
Posted: Thu Jun 11, 2015 2:33 am
by paul c
I am not sure of the change in 1991 but there are usually 3 prices for any landrover item, lowest (aftermarket) take your chances, middle range, OEM manufactured by genuine parts supplier but not supplied in genuine packages or thru the landrover supply chain, Highest Genuine in genuine packaging supplied via Landrover parts chain.
Posted: Thu Jun 11, 2015 8:01 am
by bigaldart
Later engines, ie cross bolted engines need a different sump gasket.
Alan
Posted: Thu Jun 11, 2015 9:03 am
by DEVONMAN
For engines with a non dizzy type front cover, the front cover gasket and the sump gasket are different to the earlier dizzy types.
If you are using a non dizzy front cover then you need the sump to match as there is an extra bolt at the front of the sump.
Later engines also have twin lips on the front cover oil seal. This could be to do with the fact that there is a crank driven oil pump directly behind it.
Regards Denis
Posted: Thu Jun 11, 2015 12:12 pm
by paul c
What year are the suffix B engines, in the disco the crank driven oil pump was from 1995, the facelift 300tdi era, was it earlier in the RR?
Posted: Thu Jun 11, 2015 4:58 pm
by Eliot
paul c wrote:I am not sure of the change in 1991 but there are usually 3 prices for any landrover item, lowest (aftermarket) take your chances, middle range, OEM manufactured by genuine parts supplier but not supplied in genuine packages or thru the landrover supply chain, Highest Genuine in genuine packaging supplied via Landrover parts chain.
The site even lists them as Genuine, OEM or aftermarket.
I tend to go with OEM for most parts i buy. I'll only use aftermarket/cheap-as-possibe if the impact of a failure, bad fitment or poor quality is low.
Posted: Fri Jun 12, 2015 8:31 am
by DEVONMAN
paul c wrote:What year are the suffix B engines, in the disco the crank driven oil pump was from 1995, the facelift 300tdi era, was it earlier in the RR?
I believe the suffix B engine with a crank driven oil pump was introduced in January 1994.
Regards Denis
Posted: Fri Jun 12, 2015 2:39 pm
by richardpope50
I spent a long time looking for sump gaskets and finally bought one that they said would not leak. I bought it from eBay Classseparts but they do not seem to list it at the moment. there were a few companies selling this type, though.
Impressed with it as it has not leaked and cost £25. I did do the sump bolts up a firm hand tight on a 1/4 socket that's a bit more than the torque setting but on the torque setting it had a very slight leak in several places. I'm not sure my torque setting was very accurate, though as it was via a torque drill setting.
HTH
Posted: Fri Jun 12, 2015 8:31 pm
by ged
I just used a regular cork gasket & stiffening plates to spread the load better.
Works so far.
Image[/URL]
Posted: Mon Jun 15, 2015 5:05 am
by V8aholic
ged wrote:I just used a regular cork gasket & stiffening plates to spread the load better.
Works so far.
Image[/URL]
Are the stiffening plates an OE Rover part or are they available to buy separately?
Posted: Mon Jun 15, 2015 9:54 am
by ged
I just brought some flat bar, then cut & drilled to suit.
