EFI inlet manifold
EFI inlet manifold
Couple of questions.
I'd like to use a later EFI inlet manifold (from a hotwire) to get rid of that silly heater pipe which runs under my SD1 one. But the manifold I've got has no thermostat - just the housing. Can I fit a normal one to that? Or is there an in-line type I could fit to the top hose?
It also has a temperature sensor in the fuel rail - is that of any use with a MS3X?
I thought all those manifolds were supposed to have the 'stat in there, and it was only with GEMS that the 'stat went into the bottom hose.
I guess if there is a thermostat bypass circuit, it will be OK.
If you are doing away with that pipe that runs under the manifold, what are you replacing it's function with?
There is a heater hose connection on the side of the manifold, rather than underneath as on the SD1. So I'd run a second pipe alongside the existing return one.
I suppose it's possible it's a GEMS manifold - what differences are there between that and hotwire?
Some old French cars used a stat you shoved up the inside of the top hose. I used one years ago
eg this type of thing
http://www.ebay.co.uk/itm/Replacement-T ... 463586ecbd
http://www.ebay.co.uk/itm/Gates-Thermos ... 4d2f14f392
jenand40
Post by jenand40 »
DaveEFI,
I have some photos of my heater set up with the Hotwire manifold that does not use the under manifold pipe.
I have never been able to load pictures on this forum, so if you PM me your email address I will forward them to you.
Andy.
Sent, thanks, Andy.
