Helicoil / time serts
I have two stripped threads on the heads that came with my 4.6 engine. I have made up some jigs to drill out and put inserts in, I don't want to fork out for a time sert kit, you can buy individual inserts for £3 or so, any one know what STI tap I would need for 3/8 unc time sert ?
One of the holes has been messed with and im not sure if a helicoil or time sert would work, anyone know if there are any larger OD ones available?
I guess I could make up a alloy bung and die/thread it to fit if all else fails !
You can buy helicoil kits from as low as £15 through to over £50 for a few sizes.
That's everything, drill bit, helicoils, taps etc
I've a few of the V-Coil ones in metric sizes. Handy sets to have
http://www.ebay.co.uk/itm/3-8-UNC-V-Coi ... 1c352c4fbf
Also have some "silverline" which this appears to be, again all good.
http://www.ebay.co.uk/itm/HELICOIL-TYPE ... 56688e5f1e
Thanks for the replies I have helicoils but I was asking about time serts, these kits start at £50 odd, although helicoils are fine most say time sert are better.-
http://www.youtube.com/watch?v=qFSyfY1VLtU
http://www.youtube.com/watch?v=anjDQJtWFc8
Time sert ebay-
http://www.ebay.co.uk/itm/1x-WURTH-UNC- ... 588f50d037
Time sert ebay-
- SimpleSimon
This ^ yes Time-Serts are better quality IMO but they are also more expensive toostevieturbo wrote:I cant see anything you would possibly need on most engines where you'd need anything stronger than a helicoil.
Especially as a helicoil thread insert is already stronger than a thread into the bare aluminium.
Are they exhaust threads?
I had one on my P38, drilled it out and tapped it to M12. I used a M12 Cap screw which surprisingly fitted through the existing holes on the exhaust manifold, but I also turned a "waist" on the top half of it to give it some extra clearance.
If the hole hadn't of been previously messed around with I think an M10 would of gone in, but I had to go out to M12 in order to clean the hole out.
- SimpleSimon
I had an idea about doing a heli-coil loan system.
You'd pay a deposit covering the purchase price of the kit, and get it refunded less the costs of the bits used on return. And of course a (small) additional fee to cover wear and tear.
Suggested it to the SD1 club with absolutely no interest.
Kits are dirt cheap and handy to have.DaveEFI wrote:I had an idea about doing a heli-coil loan system.
Just buy as you go, then you always have them there and then when you need them in the future.
