Page 1 of 2
Steel Billet Flywheel
Posted: Thu May 24, 2007 8:09 am
by martin_t
Can anyone advise the best place to get a Steel Billet Flywheel for and SD1?? Best I can see is V8Tuner at about £240 (plus postage but including VAT).
Martin
Posted: Thu May 24, 2007 9:16 am
by katanaman
www.djev8.co.uk does them but dont expect much cheaper as thats what they cost am afraid. Real steel will probably do them as well.
Posted: Thu May 24, 2007 3:25 pm
by ian.stewart
Ive got a DJE steel flywheel, nice piece of kit,
Posted: Thu May 24, 2007 6:04 pm
by 14500rpm
V8 Tuner do an aluminium flywheel thats only 11lbs, I don't know the pros and cons of a non-steel flywheel but it sounds tempting.
Link to V8 Tuner
Posted: Tue May 29, 2007 8:45 pm
by adamnreeves
I think the cons are basically rougher idle? Also bad idea going to light for a heavy vehicle, I think 11lbs is good for a kit car but maybe not a good idea for a range rover for example. At the end of the day the purpose of the flywheel is to store energy and the ligher it is the the less energy it stores.
The pros are the engine does not have to overcome the mass and thus the the throttle response is improved, probably good if you are doing 1/4 mile sprinting.
I am sure others more knowledgable will be along shortly.
14500rpm wrote:V8 Tuner do an aluminium flywheel thats only 11lbs, I don't know the pros and cons of a non-steel flywheel but it sounds tempting.
Link to V8 Tuner
Posted: Tue May 29, 2007 10:45 pm
by 14500rpm
I could live with some ammount of rougher idle, it would be going in an MX-5 so weight is not quite in the kit car area but hopefully less than 1100kg.
Posted: Tue May 29, 2007 11:16 pm
by adamnreeves
Should be okay I would think. 11lbs I think is the minimum, I have heard of someone going to 8lbs and apparently just kept stalling!
I have gone for a DJE 18lbs steel one and was toying with getting the v8tuner ali one but I managed to get a good deal via from DJE Ebay at the time.
14500rpm wrote:I could live with some ammount of rougher idle, it would be going in an MX-5 so weight is not quite in the kit car area but hopefully less than 1100kg.
Posted: Tue May 29, 2007 11:42 pm
by 14500rpm
18lb's sounds like it might be a better compromise, have you driven the car with it yet ?
Posted: Tue May 29, 2007 11:47 pm
by adamnreeves
Nope, not quite there yet.
14500rpm wrote:18lb's sounds like it might be a better compromise, have you driven the car with it yet ?
Posted: Wed May 30, 2007 1:37 am
by HairbearTE
The ally flywheel from v8 tuner would probably be ok since it only accepts a larger than stock cover plate anyway that will likely weigh more than the stocker. The net result will still be a whole lot lighter than the stock assembley but not undrivable I think.
Posted: Fri Jun 01, 2007 4:21 pm
by chodjinn
I have a lightweigth aluminium flywheel in my MGB. That weighs less than 950kg think. Not driven it yet tho
Posted: Sat Jun 02, 2007 6:34 am
by 14500rpm
I'd be intrested to hear your thoughts once you have driven it.
Re: Steel Billet Flywheel
Posted: Sun Jun 03, 2007 10:33 am
by martin_t
martin_t wrote:Hi
Martin
Just to come back to my flywheel dilema, I would just like an opinion as to if its actually worth it to get a steel billet version for my fairly standard RV8 3.5? I have a hurricane cam, webber 500 on an edelbrock manifold but other than that its fairly standard. Would I see any benefit or would I be better off spending money somewhere else and buying a new standard flywheel?
Martin
Posted: Sun Jun 03, 2007 12:43 pm
by pitsnow
Hi Martin
In my opininon, you won't see much benefit from the flywheel.
You wold be better of spending the money getting a 3.9 or bigger RV8 block.
As for the aluminium flywheel discussion before, I agree with Hairbear, it is no problem in a lighter car with a 10 inch clutch on top of it. My Rush has an aluminium flywheel and never given my any problems.
Peter
Posted: Sun Jun 03, 2007 3:00 pm
by Lewis
Yea, you won't get more power out of it but it'll spin up faster, if it's able to.
Can induce a whole load of problematic driving issues but you usually have to go REALLY light to get that bad!
