R380 swap from LT77
Posted: Sat Feb 22, 2014 4:39 pm
All right R380 2WD is bolted to the engine. That's all for the moment, but
SD1 remote sits further back about ½" so transmission tunnel or the gear-lever has to be modified.
trans member also sits further backwards so a modification will be needed.
Figured a Granada one with the single rubber mount might do the trick with little modifications.
Do I really need the 3 rubber mounts that holds the tranny on my whatever bracket.
Second are all the gears in the same position as my LT77 ??
There's some bracket thing on the side of the SD1 remote unit. It has two springs fitted between the two bolts. It has a plate that slides inside the remote. What does it do, and do I need it.
Its located just below the reverse switch.
This R380 has a hose on top of the gearbox. guess its venting.
Thanks , JP
Thanks , JP
