Rover V8 timing
Posted: Fri Jun 28, 2013 10:39 pm
I have just read on the V8 forum someone describing how to time up a Rover V8 and they have stated that to check the number 1 cylinder is at TDC to remove the driver's side rocker box cover and check that the valves on no. 6 are slightly open.
According to my Haynes manual it states that No. 1 cylinder is at the front left hand bank and the event numbers are on the right hand side. We were assuming that 1, 3, 5 and 7 were on the left hand bank and 2, 4, 6, 8 on the right hand bank. As stated above, they are saying to remove the driver's side rocker box to check number 6 cylinder.
Which one is correct???
Many thanks
Garry
Many thanks
Garry
