sd1 3.5
sd1 3.5
just done a compression test on my engine it was done with a cold engine and the readings were between 130 and 140 i have just read it should have been done with warm engine do these readings seem ok ? the engine is 9;35;1cr... thanks in advance
- Helpful or Confused
Compression pressure.
Workshop manual quotes 130 psi.This is for 9.35:1 engines.
Important that they are all very similar as this shows that the engine is in relatively good condition.
Engine at working temp will only improve a reading by a few psi.
Yours seems to be healthy.
