Was wondering if someone on here confirm..
If i had a 4HA Axle casing from a Scimitar and a Jag IRS unit with a CWP Ratio (3.54) i wanted and a powerlock LSD could it all be transferred into the 4HA Casing?
I have heard of the LSD being used but need to confirm that the CWP will work also?
Thanks!
4HA & Jag IRS Compatibility
They are the same diff just the tubes are different. They were actually used as a live axle in the MK11 jags.
http://www.scparts.co.uk/index/lang-2/l ... pl,x-a.htm
And some more information along with what Ian was on about
http://www.pistonheads.com/gassing/topi ... &f=149&h=0
