Air compressor spare parts ...
Posted: Mon Mar 18, 2013 9:47 am
by chodjinn
Hi all, bought a rather nice 5.5hp / 200l compressor off volospian this weekend, unfortunately it fell ove rin the van on the way back and I broke the pressure regulator thing off the top of the compressor housing. It's a small balck round thing that screws into the side/top ... anyone know where I can get spare parts from? It's a Neilson compressor.
Posted: Mon Mar 18, 2013 11:36 am
by Eliot
Would help if you could get a photo of it
Posted: Mon Mar 18, 2013 11:45 am
by chodjinn
Eliot wrote:Would help if you could get a photo of it
It's the small round black thing by the fan shroud, top left. It screws into the top of the cylinder/piston head on the compressor and has a brass attachement that has some copper pipe which goes down and atachs to the air tank. Anyone know what it is and where I can get a new one?
Posted: Mon Mar 18, 2013 3:06 pm
by Eliot
I was thinking its the feed to the tank but that brass pipe looks too small.
From some googling i've done, it looks like the air inlet filter. The pipe is possibly a pipe from a pressure release valve just going into the filter rather than venting to atmosphere.
In other words, probably not that critical or and therfore repairable.
Posted: Mon Mar 18, 2013 4:01 pm
by chodjinn
Eliot wrote:I was thinking its the feed to the tank but that brass pipe looks too small.
I really hope that you are right mate, that would be ok lol! Going to try and find a replacement.
Posted: Mon Mar 18, 2013 4:14 pm
by Eliot
Take it apart, should be fairly obvious that its a filter.
How broken is it?
Posted: Mon Mar 18, 2013 4:28 pm
by chodjinn
Eliot wrote:Take it apart, should be fairly obvious that its a filter.
How broken is it?
I actually never got round to having a proper look, but it does look a bit simple yes! It has broken right on the threaded bit that screws into the compressor head - so the entire threaded bit is stuck in. Luckily it's cast so I should be able to cut a small nick in it and use a screwdriver to tap it out. Depending on it's condition I may be able to use some petal putty etc as it's not a pressure fitting ....?
Posted: Mon Mar 18, 2013 6:20 pm
Have you looked at similar offerings in Machine Mart etc? Lots of these sort of things tend to be badge engineered. And sadly sometimes difficult to get spares for.
Posted: Tue Mar 19, 2013 8:43 am
by chodjinn
volospian just sorted me out with an ebay link for some like-for-like filters, around a fiver! Result! Just have to get the old thread out.
